AI infrastructure becomes increasingly difficult to scale as GPU environments grow. As organizations move from thousands to tens of thousands of GPUs, metadata concurrency, throughput, capacity, and namespace management can become architectural constraints that traditional storage designs struggle to address.
NetApp® Novus is a scale-out storage architecture designed for gigawatt-scale AI factories. Built on NetApp ONTAP® software, it separates metadata from the data path so metadata concurrency, throughput, and capacity can scale independently under a single namespace. The architecture is designed to support hundreds of thousands of GPUs and deliver more than 100TB/s of throughput in a single namespace.
The architecture rests on three key components:
The larger the GPU cluster, the more throughput and metadata concurrency storage needs to keep every GPU busy.
Picture a training run spread across 50,000 GPUs. At that scale, the challenge isn't just delivering enough throughput. Millions of file operations, metadata requests, namespace lookups, and checkpoint activities must also be coordinated across the environment.
Throughput remains important, but many AI environments encounter architectural limits before media bandwidth becomes the only concern. As clusters grow, metadata concurrency, namespace management, and operational complexity can become significant constraints that affect overall system efficiency.
Traditional storage architectures hit a wall because they can't scale metadata concurrency, throughput, and namespace operations independently. As clusters grow, the problems compound:
The cost is concrete. An idle GPU still draws power, takes up floor space, and ties up capital. For GPU-as-a-Service (GPUaaS) providers, every stalled GPU hour is an hour they can't bill.
One reason these challenges become difficult to solve at scale is that metadata operations often occur before payload I/O begins. Every file open, namespace lookup, checkpoint request, and access operation requires coordination before data can move through the system. As AI environments grow, the ability to process those operations concurrently can become just as important as delivering raw throughput, which is why metadata architecture becomes a critical design consideration at AI factory scale.
NetApp Novus pulls metadata out of the data path. Data flows straight to the GPUs at close to line rate, while dedicated servers handle metadata operations such as file names, locations, and access times.
NetApp Novus Data Director software runs the metadata layer on dedicated servers. When a GPU client reads or writes a file, it first retrieves the data layout from the metadata server. Then it performs direct, parallel I/O against the storage layer. No metadata round trip on every I/O. No single controller choking the data path.
Because metadata and storage are decoupled, you can scale each one independently. You can add metadata capacity for concurrency-heavy workloads and add storage systems for throughput, all under one common namespace.
The data layer runs ONTAP software specifically tuned and configured for NetApp Novus on NetApp Novus-qualified NetApp AFF A90 all-flash systems (built with additional NVRAM and a 400GB NIC). This is not a general-purpose ONTAP deployment: read-path optimizations and a performance-focused configuration prioritize the sustained data delivery AI factories need. Storage-efficiency features such as compression, deduplication, and compaction are disabled to reduce processing overhead and prioritize throughput. The result builds on ONTAP's proven data integrity, resiliency, and supported security capabilities, with familiar ONTAP management tools and APIs rather than an entirely new storage operating environment.
NetApp Novus federates ONTAP-based data resources beneath a common namespace in a cluster-of-clusters design. Add a cluster, add its throughput. Performance scales linearly with each storage system, and every GPU still sees one unified namespace without remounts or fragmentation.
GPU nodes mount NetApp Novus over the standard in-kernel NFSv4.2 client using pNFS Flex Files layouts. The nconnect mount option opens multiple TCP connections per mount for higher per-client throughput. There's no proprietary agent to qualify, patch, or troubleshoot across a fleet of thousands of GPU servers, and you manage the file system with standard tools.
NetApp Novus supports NVIDIA GPUDirect Storage, which creates a direct path between storage and GPU memory. Data bypasses the CPU and system memory bounce buffers, which cuts latency and frees CPU cycles on the GPU server for the work that actually matters.
NetApp Novus is designed for:
NetApp Novus targets organizations that operate GPU clusters at massive scale, typically 50,000 GPUs or more, and need shared, high-throughput file access across all of them.
NetApp Novus is built for:
Common workloads:
NetApp Novus can fit electronic design automation (EDA) and high-performance computing (HPC) environments where thousands of clients need access to a single namespace.
GPU optimization usually starts with schedulers, frameworks, and networking. Storage often gets checked last. It shouldn't.
GPU starvation happens when GPUs sit idle because the data pipeline can't deliver data fast enough. Common causes include metadata bottlenecks, controller-bound storage, fragmented namespaces, and checkpoint writes that stall training. The result is expensive compute doing nothing.
Storage sets the ceiling on how much of a GPU cluster's capacity you can actually use. If storage delivers 2GB/s per GPU across the whole cluster, GPUs stay busy. If it delivers less, GPUs wait. NetApp Novus raises that ceiling by serving data at close to line rate through parallel paths and scaling throughput as you add storage systems. Higher utilization on the same hardware means a better return without buying another rack.
Power is now the hard limit for many AI data centers. Every watt that goes to an idle GPU turns into heat instead of output. NetApp Novus helps in three ways:
Three design choices work together: disaggregated metadata, parallel data access through pNFS Flex Files, and direct GPU-to-storage I/O with GPUDirect Storage. Together, they deliver more than 100TB/s of sustained read throughput in a single namespace built to support hundreds of thousands of GPUs.
As AI infrastructure scales, the challenge is no longer just delivering more throughput. Metadata concurrency, namespace management, and operational complexity become increasingly important design considerations. NetApp Novus is designed to address these challenges with an architecture that separates metadata from the data path, enables independent scaling of metadata and storage resources, and maintains a single namespace across the environment.
Built on ONTAP software, NetApp Novus extends the NetApp data foundation to AI-factory scale, helping organizations support larger GPU environments while maintaining a common operating model for data management and mobility.
The key building blocks for NetApp Novus include:
To size NetApp Novus for your GPU clusters, talk to a NetApp Novus architect or read the NetApp Novus solution overview.
