What is NetApp Novus?
Topics
Compartilhar esta página
AI infrastructure becomes increasingly difficult to scale as GPU environments grow. As organizations move from thousands to tens of thousands of GPUs, metadata concurrency, throughput, capacity, and namespace management can become architectural constraints that traditional storage designs struggle to address.
NetApp® Novus is a scale-out storage architecture designed for gigawatt-scale AI factories. Built on NetApp ONTAP® software, it separates metadata from the data path so metadata concurrency, throughput, and capacity can scale independently under a single namespace. The architecture is designed to support hundreds of thousands of GPUs and deliver more than 100TB/s of throughput in a single namespace.
The architecture rests on three key components:
  • A disaggregated metadata layer
  • An ONTAP-based data layer
  • Standard, in-kernel client access through NFSv4.2, pNFS Flex Files, and NVIDIA GPUDirect Storage
The larger the GPU cluster, the more throughput and metadata concurrency storage needs to keep every GPU busy.
Why do AI enterprises need NetApp Novus?
Picture a training run spread across 50,000 GPUs. At that scale, the challenge isn't just delivering enough throughput. Millions of file operations, metadata requests, namespace lookups, and checkpoint activities must also be coordinated across the environment.
Throughput remains important, but many AI environments encounter architectural limits before media bandwidth becomes the only concern. As clusters grow, metadata concurrency, namespace management, and operational complexity can become significant constraints that affect overall system efficiency.
Traditional storage architectures hit a wall because they can't scale metadata concurrency, throughput, and namespace operations independently. As clusters grow, the problems compound:
  • Storage islands. Teams split data across separate systems to get more performance, which fragments the namespace.
  • Manual rebalancing. Engineers move workloads around by hand to dodge hot spots.
  • Remounts and sprawl. Adding capacity means touching client mounts across thousands of GPU servers.
  • Checkpoint coordination. AI teams end up acting as storage engineers to keep checkpoints from stalling training. (Nobody hired a research scientist to babysit I/O.)
The cost is concrete. An idle GPU still draws power, takes up floor space, and ties up capital. For GPU-as-a-Service (GPUaaS) providers, every stalled GPU hour is an hour they can't bill.
One reason these challenges become difficult to solve at scale is that metadata operations often occur before payload I/O begins. Every file open, namespace lookup, checkpoint request, and access operation requires coordination before data can move through the system. As AI environments grow, the ability to process those operations concurrently can become just as important as delivering raw throughput, which is why metadata architecture becomes a critical design consideration at AI factory scale.
How does NetApp Novus work?
NetApp Novus pulls metadata out of the data path. Data flows straight to the GPUs at close to line rate, while dedicated servers handle metadata operations such as file names, locations, and access times.
Disaggregated metadata architecture
NetApp Novus Data Director software runs the metadata layer on dedicated servers. When a GPU client reads or writes a file, it first retrieves the data layout from the metadata server. Then it performs direct, parallel I/O against the storage layer. No metadata round trip on every I/O. No single controller choking the data path.
Because metadata and storage are decoupled, you can scale each one independently. You can add metadata capacity for concurrency-heavy workloads and add storage systems for throughput, all under one common namespace.
ONTAP as the data layer
The data layer runs ONTAP software specifically tuned and configured for NetApp Novus on NetApp Novus-qualified NetApp AFF A90 all-flash systems (built with additional NVRAM and a 400GB NIC). This is not a general-purpose ONTAP deployment: read-path optimizations and a performance-focused configuration prioritize the sustained data delivery AI factories need. Storage-efficiency features such as compression, deduplication, and compaction are disabled to reduce processing overhead and prioritize throughput. The result builds on ONTAP's proven data integrity, resiliency, and supported security capabilities, with familiar ONTAP management tools and APIs rather than an entirely new storage operating environment.
NetApp Novus federates ONTAP-based data resources beneath a common namespace in a cluster-of-clusters design. Add a cluster, add its throughput. Performance scales linearly with each storage system, and every GPU still sees one unified namespace without remounts or fragmentation.
Standards-based access with pNFS and NFSv4.2
GPU nodes mount NetApp Novus over the standard in-kernel NFSv4.2 client using pNFS Flex Files layouts. The nconnect mount option opens multiple TCP connections per mount for higher per-client throughput. There's no proprietary agent to qualify, patch, or troubleshoot across a fleet of thousands of GPU servers, and you manage the file system with standard tools.
NetApp Novus supports NVIDIA GPUDirect Storage, which creates a direct path between storage and GPU memory. Data bypasses the CPU and system memory bounce buffers, which cuts latency and frees CPU cycles on the GPU server for the work that actually matters.
Key benefits of NetApp Novus
NetApp Novus is designed for:
  • Keeping every GPU productive. Storage and metadata constraints can limit AI infrastructure efficiency at scale. By addressing these constraints, NetApp Novus helps organizations make more effective use of GPU investments and maximize the value of deployed compute resources.
  • Scaling throughput without fragmenting the namespace. Independent scaling of metadata and storage means growth doesn't create new islands, mount points, or rebalancing projects.
  • Improving AI infrastructure efficiency. An efficient ONTAP-based data layer helps you scale within real limits on power, floor space, cost, and operations.
  • Securing multi-tenancy and QoS. Run multiple isolated tenants with encryption, policy-based resource allocation, and granular security controls, so one tenant's training job doesn't starve another's inference pipeline.
  • Standards-based clients. Standard NFS and pNFS clients help reduce client-side complexity and software risk, and they keep GPU server resources dedicated to AI workloads.
  • Enterprise-grade resiliency. ONTAP software provides a mature, secure data foundation that's been protecting customer data for decades.
  • Fit with existing environments. NetApp Novus powered by ONTAP extends their NetApp platform into AI-factory scale. Organizations benefit from a common operating environment and data management foundation designed to simplify how data moves between enterprise and AI workloads.
NetApp Novus use cases
NetApp Novus targets organizations that operate GPU clusters at massive scale, typically 50,000 GPUs or more, and need shared, high-throughput file access across all of them.
NetApp Novus is built for:
  • Neoclouds and AI cloud providers that deliver GPUaaS and need multi-tenant storage that keeps utilization, and revenue, high
  • Sovereign AI providers that need strict tenant isolation, encryption, and control over where and how data is stored
  • Hyperscalers that need throughput and namespace scale that keep pace with ever-larger GPU clusters
  • Large enterprises building private AI factories that need performance
Common workloads:
  • Foundation model training
  • Custom large language model (LLM) and small language model (SLM) training
  • Model fine-tuning and tuning
  • Inference at scale
  • Agentic AI workflows
NetApp Novus can fit electronic design automation (EDA) and high-performance computing (HPC) environments where thousands of clients need access to a single namespace.
NetApp Novus and GPU optimization
GPU optimization usually starts with schedulers, frameworks, and networking. Storage often gets checked last. It shouldn't.
What is GPU starvation?
GPU starvation happens when GPUs sit idle because the data pipeline can't deliver data fast enough. Common causes include metadata bottlenecks, controller-bound storage, fragmented namespaces, and checkpoint writes that stall training. The result is expensive compute doing nothing.
How does storage affect GPU utilization?
Storage sets the ceiling on how much of a GPU cluster's capacity you can actually use. If storage delivers 2GB/s per GPU across the whole cluster, GPUs stay busy. If it delivers less, GPUs wait. NetApp Novus raises that ceiling by serving data at close to line rate through parallel paths and scaling throughput as you add storage systems. Higher utilization on the same hardware means a better return without buying another rack.
How does NetApp Novus help power-constrained AI data centers?
Power is now the hard limit for many AI data centers. Every watt that goes to an idle GPU turns into heat instead of output. NetApp Novus helps in three ways:
  • It keeps GPUs busy, so the power you've already provisioned produces work.
  • It scales throughput by adding efficient ONTAP-based storage systems instead of sprawling infrastructure.
  • It uses GPUDirect Storage and standard clients to reduce CPU overhead on GPU servers.
What makes NetApp Novus high-performance file storage for AI?
Three design choices work together: disaggregated metadata, parallel data access through pNFS Flex Files, and direct GPU-to-storage I/O with GPUDirect Storage. Together, they deliver more than 100TB/s of sustained read throughput in a single namespace built to support hundreds of thousands of GPUs.
As AI infrastructure scales, the challenge is no longer just delivering more throughput. Metadata concurrency, namespace management, and operational complexity become increasingly important design considerations. NetApp Novus is designed to address these challenges with an architecture that separates metadata from the data path, enables independent scaling of metadata and storage resources, and maintains a single namespace across the environment.
Built on ONTAP software, NetApp Novus extends the NetApp data foundation to AI-factory scale, helping organizations support larger GPU environments while maintaining a common operating model for data management and mobility.
The key building blocks for NetApp Novus include:
  • ONTAP data management software provides the resilient, secure data layer and unifies storage and data across a single platform.
  • AFF A90 all-flash systems deliver the high-performance storage foundation for AI and machine learning workloads.
  • NetApp Novus Data Director software coordinates metadata so data can flow directly and in parallel to GPU clients.
To size NetApp Novus for your GPU clusters, talk to a NetApp Novus architect or read the NetApp Novus solution overview.
Related terms
