How to scale AI infrastructure beyond individual storage-system boundaries
Share this page
Devon Helms
Devon Helms
AI infrastructure can reach a point where the storage architecture behind the GPUs becomes the constraint. Metadata operations queue before payload data moves, individual storage clusters reach practical throughput limits, and adding more isolated systems creates more namespaces to manage. At that scale, the question is how to build a data layer that can scale metadata concurrency, aggregate throughput, and capacity independently under one namespace.
You may already run a massive GPU environment with tens of thousands of GPUs on storage that meets today’s requirements. But as the environment grows, the limiting factor can shift from the performance of an individual system to the architecture of the environment as a whole: metadata concurrency, aggregate throughput, namespace scale, and operational complexity.
NetApp® Novus is designed for that next scale of AI infrastructure. It combines a disaggregated metadata plane with NetApp Novus-qualified AFF A90 systems running ONTAP to create a single namespace that can scale beyond individual storage-system boundaries. By allowing metadata resources, aggregate throughput, and capacity to grow independently, NetApp Novus helps infrastructure teams add the resource associated with the constraint while preserving one coherent namespace as the environment expands.
Part one of this series, “Why GPUs sit idle: the real AI infrastructure bottleneck isn’t compute,” shows why low GPU productivity is often a pipeline problem rather than a compute problem: metadata operations, storage throughput, networking, preprocessing, software efficiency, and workload behavior can all leave expensive accelerators waiting. This article takes the next step.
When metadata concurrency and aggregate data delivery become architectural constraints, how should infrastructure leaders design a storage environment that can grow beyond the limits of an individual system without multiplying namespaces and operational complexity?
The architectural limits of scaling one system at a time
At gigawatt-factory scale, the central question is whether the architecture can scale metadata concurrency, aggregate throughput, and capacity beyond the limits of an individual system while keeping the namespace coherent. All with the goal of increasing GPU utilization and ensuring storage and data pipelines are not the bottleneck. That is the design problem infrastructure leaders need to solve before adding more isolated storage or more GPUs.
Evaluate the architecture across four questions: Can metadata performance scale with client and namespace activity? Can aggregate throughput and capacity grow beyond one storage-system boundary? Can those resources scale independently under one namespace? And does the deployment model match the operational capabilities available in the initial release?
The real requirement is an architecture that can grow beyond the metadata and throughput limits of an individual storage cluster without multiplying namespaces and operational complexity. NetApp Novus addresses that requirement by separating metadata from the data path and bringing multiple qualified ONTAP data resources together under one namespace.
How NetApp Novus scales beyond individual storage cluster
So what does it take to scale beyond the boundary of one storage cluster? NetApp Novus uses a disaggregated metadata plane and multiple NetApp Novus-qualified ONTAP data resources under a single namespace. The initial implementation uses purpose-configured AFF A90 systems as the data layer, providing a qualified foundation for large-scale AI workloads.
A single namespace gives applications and GPUs one consistent view across multiple NetApp Novus-qualified ONTAP data resources. NetApp Novus Data Director manages the namespace and provides layouts to clients, while clients perform direct, parallel I/O against the ONTAP data layer through standards-based pNFS and NFS access.
Within that environment, metadata resources, data-system throughput, and capacity can be added independently beneath the same namespace as workload requirements grow.
The architectural difference is how the environment scales: multiple qualified ONTAP data resources operate beneath one namespace while metadata concurrency, aggregate throughput, and capacity can grow independently.
The payoff lands differently depending on where you sit:
  • If you own uptime and the cost line, the value is a modular architecture designed to help reduce data-related GPU stalls while allowing metadata resources, aggregate throughput, and capacity to scale independently. The business case comes from reducing fragmentation and adding the resource associated with the constraint.
  • If you architect and run the storage, you get a modular environment in which metadata resources and qualified ONTAP data systems can scale independently under one namespace.
  • If you carry the strategy to the board, frame the investment around GPU productivity, operational efficiency, and a path to scale beyond individual storage-system boundaries. The long-term value comes from maximizing intelligence output from your GPU investment through independently scaling metadata and data resources beneath one namespace.
Why independent scaling under one namespace matters
Independent scaling matters because gigawatt-scale factory constraints do not always grow together. Client and namespace activity can increase metadata pressure before capacity is exhausted; aggregate throughput can become the limit while metadata resources remain sufficient. A disaggregated architecture lets operators add the resource associated with the constraint while keeping access under one namespace.
Picture a large AI infrastructure program operating thousands of GPUs under strict availability, procurement, and data-residency requirements. At that scale, the storage design must account for which systems are qualified for the data path, how the namespace grows, and how metadata, throughput, and capacity scale over time.
NetApp Novus gives that program a path to build a new AI-scale environment in which metadata and qualified ONTAP data resources can scale independently under one namespace. That can help reduce data-related GPU stalls and avoid creating a separate namespace each time the NetApp Novus environment adds data-system capacity or throughput.
The payoff is a modular AI-scale environment built on qualified systems: metadata resources can grow with namespace activity and client concurrency, while ONTAP data resources can grow with aggregate throughput and capacity.
Where this lands by environment
One architecture, applied to different AI infrastructure environments. NetApp Novus is designed for very large GPU deployments, including neocloud, sovereign AI, hyperscaler, and large enterprise gigawatt-scale factory environments, that can adopt a qualified NetApp Novus data layer and need metadata, throughput, and capacity to scale independently under one namespace.
  • Neocloud GPU cloud. Build or expand a large, qualified AI storage environment in which metadata resources and ONTAP data systems can scale independently under one namespace. The value is reducing data-related GPU stalls and avoiding a new namespace each time the NetApp Novus environment adds throughput or capacity.
  • National or sovereign AI infrastructure. Design a qualified data layer around availability, procurement, and data-residency requirements while allowing metadata, aggregate throughput, and capacity to grow independently.
  • Large enterprise gigawatt-factory scale. Use NetApp Novus when the AI environment has reached a scale at which metadata concurrency, aggregate throughput, namespace growth, and operational complexity become first-order design concerns.
The architecture remains consistent across these environments: a disaggregated metadata plane, qualified ONTAP data resources, standards-based client access, and one namespace that scales beyond individual storage-system boundaries. What changes is the operating model and business context.
A buyer checklist for AI-scale storage architecture
Validation area Questions to ask NetApp Novus consideration
Metadata architectureCan metadata performance scale with client concurrency and namespace activity independently of the data path?NetApp Novus uses a disaggregated metadata plane that scales separately from qualified ONTAP data resources.
Throughput and capacityCan aggregate throughput and capacity grow beyond one storage-system boundary without creating another namespace?Multiple NetApp Novus-qualified AFF A90 systems operate beneath one namespace, with data resources added for throughput or capacity.
Client modelDoes the architecture require proprietary client software across the GPU fleet?NetApp Novus uses standards-based pNFS and NFS access, avoiding a proprietary file-system client on GPU nodes.
Qualified deploymentWhich systems and configurations are qualified for the environment?NetApp Novus uses a qualified data layer built on purpose-configured AFF A90 systems.
Claims and evidenceWhich results are measured, modeled, forward-looking, or dependent on configuration and workload?NetApp Novus is architected to exceed 100TB/s of sequential read throughput in a single namespace for AI workloads; validate dependencies and current release scope.
Use this checklist to compare architectures on the same dimensions and to separate current capabilities from roadmap direction or modeled claims. For NetApp Novus, the key distinction is independent scaling of metadata and qualified ONTAP data resources under one namespace.
Hold every architecture, including NetApp Novus, to the same evidence standard. Ask which capabilities are available in the release being evaluated, which claims are modeled or forward-looking, what dependencies apply, and what operational limits have been validated. A specification describes intent; qualification, testing, and documented deployment evidence establish confidence.
Where to start
Start by identifying which layer is constraining useful GPU work: metadata, aggregate throughput, capacity, networking, preprocessing, or software efficiency. If metadata concurrency and storage-system boundaries are becoming the limiting factors, evaluate whether a qualified NetApp Novus environment fits the scale, deployment model, and operational requirements of the gigawatt-scale factory you are building.
Talk to a NetApp Novus architect today.
Devon Helms
Devon Helms
Devon Helms is a thirty year data management industry veteran and survivor of multiple startups. He gets energized thinking and writing about data and all its uses, sustainability, and increasing health span. A California native, Devon grew up surfing the swells of Redondo Beach as well as the early internet through bulletin board systems. But his main passion is rock climbing, a skill he honed on the razor sharp crags of Joshua Tree, CA. Devon now splits his time between his home office in the kitchen and his home office in the dining room because he loves to travel.View all Posts by Devon Helms
Scale AI infrastructure beyond individual storage-system boundaries | NetApp Blog
