As enterprises worldwide increasingly rely on Kubernetes for deploying and managing modern, cloud-native applications, robust data management and protection become crucial. Today, we’re thrilled to introduce NetApp® Trident™ 25.10, the latest version of our industry-leading open-source storage orchestrator for Kubernetes, designed to enhance scalability, performance, and resilience.
Trident 25.10 enhances scalability and performance by increasing parallelism. In this release, node parallelism for Fibre Channel (FC) is now generally available, and controller parallelism for NVMe/TCP and NFS/SMB is available as a technical preview. Here are some of the other key improvements:
Performance. Trident now supports the FC protocol for NetApp ASA systems, offering improved performance and reduced latency for data-intensive applications. This support enables a more efficient and responsive storage experience.
Advanced integration. To support AI and machine learning (ML) workloads running in Kubernetes, Trident now integrates with the new NetApp AFX product line. This integration allows your AI/ML applications to take advantage of the latest advancements in storage technology. Read more about the AFX product line in this blog.
Improved resilience. Trident 25.10 enhances the resilience of your Kubernetes clusters by automating volume failover when a Kubernetes node fails. This maintains high availability and minimizes downtime.
Greater customization. You can now specify the desired amount of CPU and memory for Trident containers. This feature helps Trident run efficiently, with enough capacity to handle any size of Kubernetes cluster.
Trident automatically provisions NetApp storage with advanced data protection features for Kubernetes applications, both on premises and in the cloud. Its ability to automate and simplify the provisioning, protection, and movement of Kubernetes workloads across hybrid and multicloud environments makes it indispensable.
In addition to its new functionality, Trident 25.10 continues to address critical business challenges.
Without Trident, NetApp wouldn’t have a comprehensive Kubernetes offering. Trident exposes the industry-leading features of ONTAP and provides additional advanced data protection and application-aware portability for disaster recovery and business continuity.
Trident 25.10 extends the number of NetApp systems available for Kubernetes workloads, ensuring that NetApp remains relevant and invaluable to our Kubernetes customers. By simplifying how you provision, protect, and move your Kubernetes workloads, Trident addresses the broad needs of developing and deploying enterprise Kubernetes applications.
Trident 25.10 continues to pave the way for strong, scalable, and resilient Kubernetes deployments, helping thousands of customers realize the full potential of the Kubernetes platform, whether on premises or in the cloud.
Luis Rico 是一位成就卓著、備受尊敬的資料儲存設備、資料保護和災難恢復專家。Luis 在過去 22 年來一直從事資料儲存設備產業的售前諮詢工作,為全球企業客戶提供服務。自 2017 年初以來,他一直致力於 Kubernetes 和 OpenShift 中的持續儲存。在 NetApp,Luis 擔任 Trident(一款來自 NetApp 用於佈建和保護 Kubernetes 應用程式的開源軟體)的首席產品經理。在加入 NetApp 之前,他曾擔任 Red Hat 的首席解決方案架構師,負責 Gluster、Ceph 和 OpenShift Data Foundation 等相關工作。
