본문으로 건너뛰기
Trident 25.10: Advanced storage solutions for Kubernetes
huge architecture buildings with sculptures
Table Of Contents
이 페이지 공유하기
Luis Rico
Luis Rico
278 조회수
As enterprises worldwide increasingly rely on Kubernetes for deploying and managing modern, cloud-native applications, robust data management and protection become crucial. Today, we’re thrilled to introduce NetApp® Trident™ 25.10, the latest version of our industry-leading open-source storage orchestrator for Kubernetes, designed to enhance scalability, performance, and resilience.
What’s new in Trident 25.10?
Trident 25.10 enhances scalability and performance by increasing parallelism. In this release, node parallelism for Fibre Channel (FC) is now generally available, and controller parallelism for NVMe/TCP and NFS/SMB is available as a technical preview. Here are some of the other key improvements:
Performance. Trident now supports the FC protocol for NetApp ASA systems, offering improved performance and reduced latency for data-intensive applications. This support enables a more efficient and responsive storage experience.
Advanced integration. To support AI and machine learning (ML) workloads running in Kubernetes, Trident now integrates with the new NetApp AFX product line. This integration allows your AI/ML applications to take advantage of the latest advancements in storage technology. Read more about the AFX product line in this blog.
Improved resilience. Trident 25.10 enhances the resilience of your Kubernetes clusters by automating volume failover when a Kubernetes node fails. This maintains high availability and minimizes downtime.
Greater customization. You can now specify the desired amount of CPU and memory for Trident containers. This feature helps Trident run efficiently, with enough capacity to handle any size of Kubernetes cluster.
Addressing your storage business challenges
Trident automatically provisions NetApp storage with advanced data protection features for Kubernetes applications, both on premises and in the cloud. Its ability to automate and simplify the provisioning, protection, and movement of Kubernetes workloads across hybrid and multicloud environments makes it indispensable.
In addition to its new functionality, Trident 25.10 continues to address critical business challenges.
  • Scalability and performance. With enhanced parallelism, Trident 25.10 efficiently manages larger Kubernetes environments and more complex workloads, maintaining high availability and reliability.
  • AI/ML workloads. Because Trident supports the new AFX product line, AI/ML workloads in Kubernetes can use advanced storage features, benefiting from the data management capabilities of NetApp ONTAP® software.
  • Resilience and high availability. The automated volume failover feature enables high availability and rapid recovery if a Kubernetes node fails, enhancing the resilience of your Kubernetes clusters. And with the customizable resource request feature, Trident maintains the right compute capacity to run safely.
Trident: The backbone of NetApp’s Kubernetes offering
Without Trident, NetApp wouldn’t have a comprehensive Kubernetes offering. Trident exposes the industry-leading features of ONTAP and provides additional advanced data protection and application-aware portability for disaster recovery and business continuity.
Trident 25.10 extends the number of NetApp systems available for Kubernetes workloads, ensuring that NetApp remains relevant and invaluable to our Kubernetes customers. By simplifying how you provision, protect, and move your Kubernetes workloads, Trident addresses the broad needs of developing and deploying enterprise Kubernetes applications.
Trident 25.10 continues to pave the way for strong, scalable, and resilient Kubernetes deployments, helping thousands of customers realize the full potential of the Kubernetes platform, whether on premises or in the cloud.
Read more about Trident and get started today.
Luis Rico
Luis Rico
Luis Rico는 데이터 스토리지, 데이터 보호 및 재해 복구 분야에서 뛰어난 역량과 명성을 자랑하는 전문가입니다. Luis는 지난 22년간 데이터 스토리지 업계에서 프리세일즈 컨설턴트로 활동하며 전 세계 기업 고객을 지원해 왔습니다. 그는 2017년 초부터 Kubernetes 및 OpenShift에서 영구 스토리지 관련 업무를 해왔습니다. NetApp에서 Luis는 Kubernetes 애플리케이션 프로비저닝 및 보호를 위한 NetApp의 오픈소스 소프트웨어인 Trident의 수석 제품 관리자입니다. NetApp 이전에는 Red Hat에서 수석 솔루션 아키텍트로 근무하며 Gluster, Ceph 및 OpenShift Data Foundation 관련 업무를 수행했습니다.
Luis Rico의 모든 게시물 보기
다음 단계
