跳轉至主要內容
Accelerate Genome Sequencing with NetApp ONTAP AI and Parabricks
Mike McNamara
Mike McNamara
Fifteen years ago, the first human genome was sequenced. It had taken 20 years and had cost almost $3 billion. Today it’s possible to sequence 3 billion base pairs in under a day and for less than $1,000, making it feasible to use whole genome sequencing for research and clinical applications.
As the demand for genome sequencing grows, researchers are generating a tidal wave of data that doubles in size every year. The data that’s generated by whole genome sequencing requires massive amounts of compute power, storage, and data management that can easily become a bottleneck. To keep up with the increased demand for sequencing, organizations like yours must be able to complete more sequencing jobs in less time without sacrificing accuracy or security.
NetApp partner Parabricks has high-performance GPU-accelerated genomic analysis software that speeds up the processing time of genomic pipelines. With standard CPU-based approaches, processing can take days, but with Parabricks, it takes only minutes. Parabricks software in combination with the NetApp® ONTAP® AI proven architecture, powered by NVIDIA DGX supercomputers and NetApp cloud-connected storage, enables you to deploy a fully integrated, end-to-end AI solution that’s tuned for compute- and data-intensive genomic workloads.
With this joint solution, you can:
  • Accelerate genome sequencing by an average of 50 times compared with CPU-only solutions.
  • Perform more genomic analysis operations in less time with industry-leading cloud connected all-flash storage from NetApp and NVIDIA DGX servers.
  • Protect sensitive genomic data while you improve test accuracy for AI-powered precision calculations.
  • Lower your TCO with industry-leading data-efficiency technologies and the advantage of 25 times greater capacity than with competitive systems.
  • Accelerate your return on investment with simplified integration, automation, and orchestration of data in clouds and on the premises.
The following graph shows the speed-up in whole genome sequencing (WGS) that the Parabricks and NetApp solution achieved in testing compared with a CPU-only solution. This test included ONTAP AI with a NetApp AFF A800 storage controller, eight NVIDIA Tesla V100 SXM2 32GB GPUs, Ubuntu 16.04, and 526GB of memory.
With Parabricks on ONTAP AI, you can optimize throughput to complete more genomic processing jobs in less time. This integrated solution gives you the flexibility to scale to accommodate more genomic tasks and to meet increased customer demand. You can also eliminate guesswork and get started faster with a validated reference architecture that detangles design complexity.
Start accelerating your genome sequencing workflows, improving test accuracy, and lowering your TCO today. For more information about the Parabricks and NetApp joint solution, read the white paper.
Mike McNamara
Mike McNamara
Mike McNamara 是 NetApp 產品和解決方案行銷的資深主管,在資料管理和雲端儲存行銷領域擁有超過 25 年的豐富經驗。在十年前加入 NetApp 之前,Mike 曾任職於 Adaptec、Dell EMC 和 HPE 等公司。Mike 是推出第一方雲端儲存產品和業界第一款雲端連線 AI/ML 解決方案 (NetApp)、統一化橫向擴充和混合雲儲存系統與軟體 (NetApp)、iSCSI 和 SAS 儲存系統與軟體 (Adaptec),以及光纖通道儲存系統 (EMC CLARiiON) 的重要團隊領導者。此外他曾經擔任「光纖通道產業協會 (Fibre Channel Industry Association,FCIA)」的行銷主席,也是乙太網路技術高峰會議顧問委員會、乙太網路聯盟的成員,現在仍定期為業界期刊撰稿,並經常擔任活動講師。Mike 還透過 FriesenPress 出版了一本名為《橫向擴充儲存設備 - 企業資料管理的未來樣貌》的書籍,並被 Kapos 列為值得關注的 50 名 B2B 產品行銷人員。查看 Mike McNamara 的所有文章
後續步驟
