跳轉至主要內容
Proactive Risk Management with Active IQ
Laurence James
Laurence James
I will start with an admission. I used to manage the largest supercomputer that was available at the time—the bleeding edge of technology in its day. This machine, although extremely fast at scalar and floating-point operations, was a nightmare to manage. When it worked, all was well. But when it broke, it meant many hours on the phone or in the data center to troubleshoot, usually at the most inconvenient time.
Back then, very little intelligence came from a system to give the tired staff any clue about its general heath. If you wanted something, you wrote it yourself, usually by analyzing reams of syslog output. Activities such as capacity planning and performance management were similarly challenging. You had to understand the heartbeat of those beasts, but the outcome was pretty much driven by reacting to events.
Fast-forward a few years: Now I find myself looking at the evolution of system, service, and risk management—Active IQ. If you have an active NetApp support contract, you have access to Active IQ, no expensive third-party products are required. But what does it give you?
If you enable Active IQ, NetApp can collect health and configuration telemetry from your system. Many customers take advantage of this opportunity, and some 300,000 systems worldwide provide this data. The collected data forms a lake of 200 billion data points—over 4PB in size. Telemetry data can be collected from all NetApp data management systems and software, converged infrastructure, hybrid cloud infrastructure, scale-out architectures, and object systems.
Those metrics are impressive. But they hide the plain fact that this data lake represents the potential for supplying insight that’s based on collective knowledge and that, if shared, could help businesses worldwide make better-informed decisions. Incident investigation often relies on recognizing and identifying patterns after the fact. Backed by the resources that Active IQ insights provide, you have the data and the tools to recognize and to act on incidents before they occur. Acting as the analytics and presentation layer, Active IQ uses systems data and the vast data lake as its feed. Artificial intelligence and machine learning techniques are incorporated in Active IQ and are particularly good at analyzing patterns to deliver intelligence that you can act on proactively.
Given the supercomputer support scars from my early career, I find myself saying, “I wish I knew then what I know now.” And I still want to know more. It turns out that this collective intelligence also delivers several advisory services. One that stands out to me is the Active IQ advisor that identifies efficiency and advisories for workloads, followed up by recommendations such as moving identified workloads to flash storage. The stampede to flash continues, and these advisory services bring confidence and support to the process of advising your business and IT management.
Take advantage of community wisdom to simplify and to enhance your system and risk management. Learn more about what Active IQ can do for you.
Laurence James
Laurence James
Laurence 的職責是提高 NetApp 產品在 EMEA 地區的市場知名度,他專注於推動業務成長,使 NetApp 的產品更加符合客戶和市場的需求。 Laurence 的工作涉及 NetApp 所有產品,他十分熟悉不同客戶的各種需求,能利用整個產品套件來創造更大價值。 他現在正帶領一個經驗豐富的專職團隊,協助開發和執行各種行銷活動,以鞏固 NetApp 雲端基礎架構產品的地位。 Laurence 在企業 IT 的各個方面都擁有多年工作經驗,並曾任職於 Oracle、Sun Microsystems 和 StorageTek, 他也曾擔任英國氣象局的首席 IT 顧問近 20 年。查看 Laurence James 的所有文章
後續步驟
Proactive Risk Management with Active IQ | NetApp Blog
