본문으로 건너뛰기
Proactive Risk Management with Active IQ
Laurence James
Laurence James
I will start with an admission. I used to manage the largest supercomputer that was available at the time—the bleeding edge of technology in its day. This machine, although extremely fast at scalar and floating-point operations, was a nightmare to manage. When it worked, all was well. But when it broke, it meant many hours on the phone or in the data center to troubleshoot, usually at the most inconvenient time.
Back then, very little intelligence came from a system to give the tired staff any clue about its general heath. If you wanted something, you wrote it yourself, usually by analyzing reams of syslog output. Activities such as capacity planning and performance management were similarly challenging. You had to understand the heartbeat of those beasts, but the outcome was pretty much driven by reacting to events.
Fast-forward a few years: Now I find myself looking at the evolution of system, service, and risk management—Active IQ. If you have an active NetApp support contract, you have access to Active IQ, no expensive third-party products are required. But what does it give you?
If you enable Active IQ, NetApp can collect health and configuration telemetry from your system. Many customers take advantage of this opportunity, and some 300,000 systems worldwide provide this data. The collected data forms a lake of 200 billion data points—over 4PB in size. Telemetry data can be collected from all NetApp data management systems and software, converged infrastructure, hybrid cloud infrastructure, scale-out architectures, and object systems.
Those metrics are impressive. But they hide the plain fact that this data lake represents the potential for supplying insight that’s based on collective knowledge and that, if shared, could help businesses worldwide make better-informed decisions. Incident investigation often relies on recognizing and identifying patterns after the fact. Backed by the resources that Active IQ insights provide, you have the data and the tools to recognize and to act on incidents before they occur. Acting as the analytics and presentation layer, Active IQ uses systems data and the vast data lake as its feed. Artificial intelligence and machine learning techniques are incorporated in Active IQ and are particularly good at analyzing patterns to deliver intelligence that you can act on proactively.
Given the supercomputer support scars from my early career, I find myself saying, “I wish I knew then what I know now.” And I still want to know more. It turns out that this collective intelligence also delivers several advisory services. One that stands out to me is the Active IQ advisor that identifies efficiency and advisories for workloads, followed up by recommendations such as moving identified workloads to flash storage. The stampede to flash continues, and these advisory services bring confidence and support to the process of advising your business and IT management.
Take advantage of community wisdom to simplify and to enhance your system and risk management. Learn more about what Active IQ can do for you.
Laurence James
Laurence James
Laurence는 EMEA 전역에서 NetApp 제품의 시장 인지도를 높이는 일을 맡고 있습니다. Laurence는 비즈니스 성장에 역점을 두고 NetApp 제품을 고객 및 시장 요구사항에 맞추기 위해 노력합니다. 또한 모든 NetApp 제품을 두루 살피며 다양한 고객 요구사항을 깊이 있게 이해하여 제품군 전체에서 가치를 창출합니다. 풍부한 경험을 갖춘 전담 팀과 협력하여 이제 NetApp 클라우드 인프라 제품의 포지셔닝을 지원하는 캠페인을 개발 및 구현하고 있습니다. Laurence는 몇 년에 걸쳐 엔터프라이즈 IT의 모든 측면을 담당했으며 Oracle, Sun Microsystems, StorageTek에서 중요한 역할을 맡았습니다. 약 20년간 영국 기상청의 IT 수석 컨설턴트로 근무한 경력을 보유하고 있습니다.Laurence James의 모든 게시물 보기
다음 단계
