メインコンテンツへスキップ
Optimize Data Management and Analytics with NetApp Solutions for Hadoop
Mike McNamara
Mike McNamara
59 閲覧
With NetApp® technology, you get flexibility and choice based on your use case. If you want to use data management by Hadoop Distributed File System (HDFS), we provide NetApp FAS and AFF systems and NetApp E-Series and EF-Series systems. FAS and AFF systems are certified with Hortonworks Data Platform (HDP) 3.0.0, and E-Series and EF-Series systems are certified with HDP 2.6.5. E-Series and EF-Series systems are also Cloudera certified.
If you need a more optimized in-place analytics solution and you don’t require HDFS, you can use the NetApp In-Place Analytics Module. You gain the following key advantages from the NetApp In-Place Analytics Module compared with competitors’ offerings:
  • A single source or copy of data versus a minimum of two or three copies
  • A reduced data footprint by using deduplication and compression; data reduction of between 5 and 10 times compared with HDFS deployments
  • A unified data lake architecture between Hadoop and artificial intelligence (AI) and deep learning (DL) workloads
  • Quick NetApp Snapshots™ copies for testing and development and easy space-efficient backups
  • Ability to run analytics on data that’s in NFS storage
  • Support for new Hadoop features without upgrading the storage
  • Ability to scale storage and compute independently
  • Support for data security by using Ranger and Kerberos
  • Identical architectures between on-premises deployments and cloud deployments by using NetApp Cloud Volumes Service
The following figure depicts in-place analytics on a Hadoop/Spark cluster.
HDP 3.0.0 Certified with NetApp Cloud Volumes
In the cloud, the configuration with HDP 3.0.0 is certified with NetApp Cloud Volumes ONTAP® technology and Cloud Volumes Service running HDFS over NFS. Cloud Volumes Service is a cloud-native service that gives you high-performance file storage in the cloud, with NFS and SMB connectivity. You get rich data management, such as efficient Snapshot copies and clones, as well as an integrated backup service. You can deploy Cloud Volumes Service in seconds with three different performance tiers on AWS or on Google Cloud Platform. If you use Azure, you can deploy a similar native Azure service called Azure NetApp Files, which is also built on NetApp technology.
The certified configuration with HDP 3.0.0 enables you to take advantage of the performance and reliability of Cloud Volumes Service in the cloud. At the same time, you benefit from the data management capabilities that are built into HDFS.
NetApp has been supporting Hadoop for many years to deliver advanced solutions for big data analytics. With NetApp technology, you get industry-leading storage and data management that complements your Hortonworks Data Platform that’s built on Hadoop.
Find out how you can optimize data management and accelerate data analytics with NetApp. For more information, visit netapp.com/bigdata.
Mike McNamara
Mike McNamara
Mike McNamaraは、NetAppの製品およびソリューション マーケティング担当シニア リーダーであり、25年以上にわたってデータ管理とクラウド ストレージ マーケティングに携わってきました。10年以上前にNetAppに入社する前は、Adaptec、Dell EMC、HPEで勤務していました。また、主要なチーム リーダーとして、ファーストパーティのクラウド ストレージ サービスや、業界初のクラウド対応AI/MLソリューション(NetApp)、ユニファイド スケールアウトおよびハイブリッド クラウド ストレージ システムおよびソフトウェア(NetApp)、iSCSIおよびSASストレージ システムおよびソフトウェア(Adaptec)、ファイバチャネル ストレージ システム(EMC CLARiX)の発売を推進しました。過去には、Fibre Channel Industry Associationのマーケティング分野の議長を務めたこともあり、Ethernet Technology Summitの諮問会議や、Ethernet Allianceの現役メンバーとして、業界誌に頻繁に寄稿しているほか、各種イベントにスピーカーとして数多く登壇しています。さらに、FriesenPressより『Scale-Out Storage - The Next Frontier in Enterprise Data Management』というタイトルの書籍を発行しているほか、KaposによりB2B製品マーケティング担当トップ50に選出されたこともあります。Mike McNamaraのすべての投稿を見る
次のステップ
Optimize Data Management & Analytics with NetApp Solutions for Hadoop | NetApp Blog
