跳轉至主要內容
Migrating from Dell EMC PowerScale to Amazon FSx for NetApp ONTAP
Table of Contents
分享本頁
Will Stowe
Will Stowe
As the perpetual march to the cloud rolls on, enterprise customers are mulling over options for migrating existing workloads in the data center to equivalent cloud services. They seek to gain efficiencies for the business by taking advantage of the operational scale and performance offered by Amazon Web Services (AWS), Microsoft Azure, and Google Cloud Platform (GCP). Often, the challenge with this exercise is selecting an appropriate solution because there are multiple to choose from (including IaaS, marketplace, and native offerings), and how to migrate the data.
Why?
Data is at the heart of practically every application. Storage of this data is paramount to the success of the business. But for customers currently using Dell EMC PowerScale (in other words, Isilon or OneFS), the opportunity to take advantage of AWS native services has proven to be difficult. The option to rehome this dataset onto a native service on AWS that is performant, reliable, and offers rich data management features hasn’t been open until recently.
At AWS Storage Day 2021, AWS announced the availability of Amazon FSx for NetApp ONTAP. With Amazon FSx for NetApp ONTAP, customers can leverage best of breed storage as a native AWS offering, meaning it’s fully managed and supported by Amazon. Migration from PowerScale to this new offering is very straightforward compared to other means, and allows you to move your data closer to other resources in the AWS cloud.
Networking Prerequisites
A key tenet of the hybrid cloud is the connecting and/or extending your on-premises network to the target Virtual Private Cloud or VPC. AWS Direct Connect or Site-to-Site VPN are common methods for connecting networks. They open up the path for data transport between a source PowerScale cluster and a target FSx for NetApp ONTAP solution (example topology below):
Screen Shot 2021-11-02 at 17.55.19
Migration of Data
While there are many services and tools that can be used for data migration we’ll focus on a specific tool in this post: NetApp Cloud Sync. Cloud Sync provides a simple way to replicate to and from a wide variety of end points and protocols. Data is copied from the source cluster to FSx for NetApp ONTAP as either a single/one time copy or an ongoing scheduled task.
To get started, sign up or login to NetApp Cloud Central, and select Cloud Manager from the Fabric View landing page (or connect to Cloud Manager directly via this link ).
Screen Shot 2021-11-02 at 17.56.23
Once you’re logged into Cloud Manager, you’ll need to set up shop and create a few items:
  • Workspace ‚Äì This allows for the creation of objects to be managed via Cloud Manager
  • Connector ‚Äì Allows for connectivity and resource creation for a cloud provider (in this case, we’ll spin up one for AWS)
  • Working environment for FSx for NetApp ONTAP ‚Äì this process either creates a new filesystem or allows for the discovery of an existing filesystem for use
  • Create a target volume for the data being copied from the source cluster
After adding the FSx for NetApp ONTAP filesystem, you should see the FSx instance:
Screen Shot 2021-11-02 at 17.57.28
Select the FSx instance, and details will be listed on the right-hand blade. Under Services, select Sync, then Sync data to this location.
Screen Shot 2021-11-02 at 18.05.48
For this example, we’ll use an NFS source volume. Drag and drop the “NFS Server” option to the “Drag Source Here” box.
Screen Shot 2021-11-02 at 18.06.33
The FSx filesystem is our default target, however we do need to select the protocol required. So, click on NFS for this exercise then click Continue.
Screen Shot 2021-11-02 at 18.07.13
Cloud Sync requires a helper VM to be deployed either in the cloud or on premises to facilitate a connection to the source (in our case, the PowerScale cluster) and the data movement to the target (FSx for NetApp ONTAP). Refer to the Cloud Sync documentation for detailed steps and requirements.
Screen Shot 2021-11-02 at 18.08.31
Now, we’ll enter the IP address of the NFS export on the source cluster.
Screen Shot 2021-11-02 at 18.09.10
And select the recently deployed Data Broker.
Screen Shot 2021-11-02 at 18.09.49
The Data Broker will then scan the source NFS exports, choose your preferred volume and select Continue.
Screen Shot 2021-11-02 at 18.10.26
Select the target FSx filesystem.
Screen Shot 2021-11-02 at 18.11.05
And select the target FSx volume.
Screen Shot 2021-11-02 at 18.11.49
You can change the NFS version, if needed (v3, v4.0, v4.1).
Screen Shot 2021-11-02 at 18.12.29
Select the target directory.
Screen Shot 2021-11-02 at 18.13.09
The select the desired properties for the sync relationship.
Screen Shot 2021-11-02 at 18.14.10
Finally, select “Create Relationship” when you’re ready to define the source/target in Cloud Sync and begin moving data.
Screen Shot 2021-11-02 at 18.15.02
The data copy process starts! You can monitor progress on the Sync dashboard.
Screen Shot 2021-11-02 at 18.15.37
Again, monitor the progress of the data copy via the dashboard. Once complete, you’re ready to mount the data from the FSx for NetApp ONTAP volume on an EC2 host in AWS.
Screen Shot 2021-11-02 at 18.16.16
Closing Thoughts
Amazon FSx for NetApp ONTAP is a highly available (active/passive across Availability Zones in an AWS region), high performance storage solution that provides rich data management features. It allows for a wide range of critical enterprise workloads to be easily migrated to an AWS native service without compromise.
Getting started with Amazon FSx for NetApp ONTAP is simple. If you’re looking for additional information on NetApp solutions please visit NetApp Cloud Central.
Will Stowe
Will Stowe
Will Stowe is based in Austin, Texas and has been with NetApp for 11 years. Will manages a team of highly skilled data engineers focused on developing solutions for modern data engineering workloads. In his free time he enjoys the art of barbeque, literature, and the occasional off-road endeavor.
查看 Will Stowe 的所有文章
