選單
Data Sovereignty without compromise
Control your data on your terms
NetApp delivers the intelligent data infrastructure required to navigate the complex landscape of digital sovereignty, balancing strict compliance with the agility needed for innovation.
Defining Data Sovereignty in a global landscape
Data Sovereignty poses a challenge for global enterprises balancing local regulations like GDPR with the scalability of the global cloud. NetApp solves this by combining security and agility, helping organizations align compliance and privacy with operational efficiency.
Resources for the sovereign enterprise
Navigating the AI paradox in data sovereignty
NetApp infrastructure lets you bring AI to your data, not the other way around. By controlling the software supply chain and using secure sovereign environments, organizations can use advanced AI without compromising data privacy or control.
Empowering European business with sovereign cloud
For European organizations, reliance on non-EU hyperscalers often raises concerns regarding the US CLOUD Act and data extraterritoriality. NetApp is uniquely positioned to guide your organization through the complexities of digital sovereignty. We understand that sovereignty is not a binary choice but a spectrum. Our approach allows you to maintain control over your data, not your cloud provider.
Unmatched Security
We offer the safest place to store your data, with top-level certifications including Common Criteria and FIPS 140-2.
Total Control
Our external key management ensures that you, and only you, hold the keys to your data. Even if data is intercepted, it remains inaccessible to unauthorized parties.
Local Expertise
We collaborate with local sovereign cloud providers across Europe, ensuring that your data resides in compliant environments managed by trusted local operators.
Future-Proof Infrastructure
Our solutions are designed to adapt to evolving regulations, providing the flexibility to shift workloads securely as compliance needs change.
Sovereignty isn't static or a switch that can be toggled. Regulations change, cyber threats evolve, and business priorities shift. The future lies in understanding the spectrum and finding the balance point that's just right for your organization.
Adam Gale, Field CTO for AI & Cyber Security, NetApp
Get started
Drift chat loading
