Data loss is unacceptable. Brilliantly engineered and simple to use, our backup and recovery solutions help ensure a quick and full recovery from events you can’t control.
Data loss, or loss of access to data, can be – and usually is – devastating. According to a University of Texas study, 94% of companies that suffer catastrophic data loss do not survive – 43% never reopen and 51% close within two years.
As the global leader in cloud data services, storage systems, and software, our reputation depends on delivering the most advanced backup and recovery solutions for end-to-end protection across your entire data fabric.
NetApp Backup and Recovery leverages the native protection features of ONTAP to efficiently backup your data to another ONTAP device or the object storage of your choice, on premises or in the cloud. Dramatically accelerate backup and restore of data in as little as seconds with integrated block-level replication and application integration via a simple user interface or RESTful APIs. Get a single control plane for our backup and recovery service.
NetApp® SnapCenter® software simplifies backup, restore, and clone management across disparate applications and infrastructures, while letting you delegate management to application and database owners without sacrificing control or oversight.
Protect your data affordably and securely with StorageGRID object storage. Meet your regulatory, performance, and scalability needs with this turn-key solution.
Dense, high throughput hybrid flash storage is ideal for streaming backup.
Seamlessly manage, optimize, and protect your secondary workloads with FAS hybrid flash unified storage.
GigaOm recognizes NetApp as a Leader and Fast Mover in the 2023 Sonar for File-Based Ransomware Protection.
Learn how S&P Global protects critical data with reliable backup, recovery, and resilience solutions.
NetApp storage technology enables maximum resiliency for mission-critical datasets.
Cost-savings and flexibility for a new era of growth.
NetApp’s data protection and security partners integrate with ONTAP data protection to deliver best of breed protection across your hybrid cloud.
