Zum Hauptinhalt springen
AI-ready data pipelines: Transforming raw data into AI value
3 pipes laid down in farmland
Table Of Contents
Diese Seite teilen
Mackinnon Giddings
Mackinnon Giddings
135 Aufrufe
Data preparation is a bottleneck that transforms data scientists into "data janitors" instead of AI innovators. While organizations rush to deploy AI, most struggle with a fundamental challenge: Their enterprise data isn't AI ready. Traditional data pipeline approaches create silos, require costly data movement, and introduce governance gaps that prevent AI from reaching production scale.
AI factories require data integration that transforms raw enterprise data into AI-ready assets seamlessly, without compromising security or duplicating storage. NetApp and NVIDIA deliver this AI-ready data pipeline, eliminating preparation roadblocks while preserving enterprise governance. This integration transforms the AI development experience through three core capabilities: unified data access, intelligent preparation services, and production-ready NVIDIA integration.
Enterprise AI data preparation: Breaking down the data prep problem
Data scientists spend the majority of their time sourcing, moving, and preparing data instead of developing models and generating insights. This isn't a technical preference—it's a structural problem created by fragmented enterprise data landscapes that scatter information across file, block, and object storage systems. Each storage type requires different access methods, preparation tools, and governance approaches, forcing data scientists to navigate multiple interfaces, learn different APIs, and manage inconsistent security models just to access the data they need for AI projects.
Manual processes compound this complexity exponentially. Traditional data preparation requires custom scripts, manual transformations, and repeated data movement between systems. Each AI project reinvents data preparation workflows, creating technical debt and introducing consistency risks. Teams spend weeks building data pipelines that should take days, while governance complexity creates additional friction as organizations struggle to maintain security, compliance, and data lineage while preparing data for AI workloads. This process often requires bypassing established controls or creating shadow IT solutions, forcing an impossible choice between maintaining governance and accelerating AI development.
Traditional pipeline limitations become apparent at enterprise scale. Data movement overhead creates storage costs and introduces consistency issues as data ages across multiple copies. Siloed preparation tools increase complexity and require specialized expertise, while manual processes don't scale to enterprise data volumes. Security gaps emerge when data movement bypasses established governance controls, leading to measurable business impact. AI projects stall in data preparation phases rather than delivering business value, data science teams function as infrastructure specialists instead of building innovative solutions, and organizations incur increased infrastructure costs from data duplication and inefficient workflows while facing compliance risks from ungoverned data movement.
Unified data integration: NetApp's AI-ready data pipeline solution
NetApp eliminates data silos through unified access that makes file, block, and object storage accessible through a single platform, transforming existing enterprise data into AI-ready assets without movement or duplication. This unified approach processes and prepares data where it lives, eliminating costly migration projects while maintaining data consistency. Consistent management applies the same tools, policies, and capabilities across all data types and storage formats, allowing data scientists to work with familiar interfaces regardless of underlying storage architecture. And IT teams maintain governance through established processes without creating AI-specific exceptions or shadow systems.
Enterprise-grade data services provide the foundation for AI-ready pipelines through global data visibility that creates a unified catalog across the entire data estate, enabling fast discovery and access. Automated classification identifies data types, sensitivity levels, and preparation requirements without manual intervention, while policy enforcement automatically applies governance rules throughout data transformation workflows. This comprehensive approach extends across hybrid cloud environments, providing consistent data services across on-premises, cloud, and edge deployments while maintaining unified data management regardless of where AI workloads are executed.
AI-optimized capabilities deliver both performance and efficiency through high-performance that provides consistent throughput for AI workload requirements. Advanced compression and deduplication reduce storage footprint without sacrificing performance, while NetApp® Snapshot™ technology creates instant, space-efficient copies that enable parallel development and testing workflows. Enterprise reliability ensures AI pipeline continuity through built-in availability and protection, supporting diverse AI deployment models while preserving governance and operational consistency across all environments.
NVIDIA AI data platform integration: Blueprints and NVIDIA NIM for enterprise AI
NetApp storage is fully validated within the NVIDIA AI Data Platform reference design, providing a seamless integration backbone for predictable performance and enterprise-grade supportability. Enterprise data is constantly growing and changing. The AIDP reference design's architecture continually monitors data sources and leverages GPU acceleration to make that data readily available rapidly. This foundation supports NVIDIA Blueprints and NIMs integration that accelerates AI workflow development by providing pretrained, customizable AI workflows for common enterprise use cases, including multimodal RAG, video search and summarization, and deep research with agentic reasoning.
As a part of NVIDIA’s AI Enterprise support, NetApp storage optimizes NVIDIA NIM inference microservices deployment and scaling. This integration with NVIDIA enables automated, efficient data transformation powered by NIMs, creating a production-ready AI deployment that simplifies the path from development to production. Now data scientists can access enterprise data through familiar AI development tools and frameworks without learning new storage interfaces. Unified infrastructure management reduces the complexity of production AI deployment, and native integration eliminates custom development and reduces time to production.
The scalable architecture grows seamlessly with AI demands, scaling from pilot projects to enterprise-wide AI deployment without requiring architectural redesign as AI workloads mature and expand across business units. This scalability means that initial AI factory investments support long-term enterprise AI strategy, giving organizations a platform that evolves with their AI maturity while maintaining consistent performance and governance standards.
Building the AI-ready data foundation
AI factory success depends fundamentally on eliminating the data preparation bottleneck that consumes 80% of AI development effort. Organizations that invest in unified data integration capture competitive advantages while those struggling with fragmented pipelines fall behind in AI innovation and business transformation. The NetApp and NVIDIA collaboration delivers the AI-ready data pipeline that transforms existing enterprise data into AI value without compromise, providing purpose-built integration that outperforms point solutions when AI becomes business critical and data preparation must scale to enterprise demands.
As AI workloads demand real-time access to enterprise data, unified data pipelines become the foundation of AI factory success. The choice is clear: continue struggling with manual data preparation and fragmented workflows or build the unified data foundation that makes AI innovation inevitable. Organizations must evaluate their current data preparation workflows and plan for an AI-ready data pipeline infrastructure that preserves governance while accelerating innovation. The organizations that solve the data preparation challenge today will lead tomorrow's AI-driven business transformation.
Getting started
To get started, learn more about NetApp AI solutions.
Take the first steps to becoming an AI expert by completing the AI Maturity self-assessment.
Mackinnon Giddings
Mackinnon Giddings
Mackinnon joined NetApp and the Solutions Marketing team in 2020. In her time, she has focused on Enterprise Applications and Virtualization, but uncovered a passion in Artificial Intelligence and Analytics. In her current role as a Marketing Specialist, Mackinnon strives to push messaging and solutions that focus on the intersection of authentic human experience and innovative technology. With a background that spans industries like Software Development, Fashion, and small business operations, Mackinnon approaches AI topics with a fresh, outsider perspective. Mackinnon holds a Masters of Business Administration from the Leeds School of Business at the University of Colorado, Boulder. She continues to live in Colorado with an often sleeping greyhound and a growing collection of empty Margaux bottles.Alle Beiträge von Mackinnon Giddings anzeigen
Nächste Schritte
