メインコンテンツへスキップ
Speed up your data science initiatives
Mike McNamara
Mike McNamara
NetApp and Run:AI have partnered to simplify the orchestration of AI workloads, streamlining the process of both data pipelines & machine scheduling for DL.Fast experimentation and successful business outcomes of AI are directly correlated, but many AI projects are rife with inefficient processes. The combination of data processing time and outdated storage solutions creates bottlenecks and workload orchestration issues, and static allocation of GPU compute resources limits the number of experiments that researchers can run.
NetApp and Run:AI have partnered to simplify the orchestration of AI workloads, streamlining the process of both data pipelines and machine scheduling for deep learning (DL). With the NetApp® ONTAP® AI proven architecture, you can fully realize the promise of AI and DL by simplifying, accelerating, and integrating your data pipeline. And to help your researchers manage and optimize GPU utilization, Run:AI’s orchestration of AI workloads adds a Kubernetes-based scheduling and resource utilization platform.
Together, NetApp and Run:AI products enable numerous experiments to run in parallel on different compute nodes, with fast access to many datasets on centralized storage. With the combined solution from NetApp, NVIDIA, and Run:AI, you get an infrastructure stack that is purpose-built for enterprise AI workloads.
Infrastructure stack for AIBy using Run:AI’s centralized resource pooling, queueing, and prioritization mechanisms together with NetApp ONTAP AI, your researchers are removed from infrastructure management hassles and can focus exclusively on data science. You can increase productivity by running as many workloads as you need without bottlenecks in your compute or data pipeline. And with the Run:AI scheduler and virtualization technology, you can easily use fractional GPUs, integer GPUs, and multiple nodes of GPUs for distributed training on Kubernetes. In that way, AI workloads run based on need, not on capacity. Your data science teams can run more AI experiments on the same infrastructure.
Run:AI DashboardWith NetApp and Run:AI technology, if your company scales AI, you get a double benefit: faster experiments and full resource utilization. To learn how to streamline and accelerate your data science initiative, read the technical report.
Mike McNamara
Mike McNamara
Mike McNamaraは、NetAppの製品およびソリューション マーケティング担当シニア リーダーであり、25年以上にわたってデータ管理とクラウド ストレージ マーケティングに携わってきました。10年以上前にNetAppに入社する前は、Adaptec、Dell EMC、HPEで勤務していました。また、主要なチーム リーダーとして、ファーストパーティのクラウド ストレージ サービスや、業界初のクラウド対応AI/MLソリューション(NetApp)、ユニファイド スケールアウトおよびハイブリッド クラウド ストレージ システムおよびソフトウェア(NetApp)、iSCSIおよびSASストレージ システムおよびソフトウェア(Adaptec)、ファイバチャネル ストレージ システム(EMC CLARiX)の発売を推進しました。過去には、Fibre Channel Industry Associationのマーケティング分野の議長を務めたこともあり、Ethernet Technology Summitの諮問会議や、Ethernet Allianceの現役メンバーとして、業界誌に頻繁に寄稿しているほか、各種イベントにスピーカーとして数多く登壇しています。さらに、FriesenPressより『Scale-Out Storage - The Next Frontier in Enterprise Data Management』というタイトルの書籍を発行しているほか、KaposによりB2B製品マーケティング担当トップ50に選出されたこともあります。Mike McNamaraのすべての投稿を見る
次のステップ
