跳转至主要内容
Generally Available: Azure NetApp Files Application Volume Group for Oracle
March 25, 2025
Application volume group (AVG) for Oracle enables you to deploy all volumes required to install and operate Oracle databases at enterprise scale, with optimal performance and according to best practices, in a single one-step and optimized workflow. The application volume group feature is using the Azure NetApp Files ability to place all volumes in the same availability zone as the VMs to achieve automated, latency-optimized deployments. With application volume group for Oracle numerous technical enhancements have been introduced that simplify, standardize, and streamline the entire process of volume deployments for Oracle in a single 'atomic' operation (through portal, RP, or API).
Azure NetApp Files application volume group for Oracle will shorten database deployment time and increase overall application performance and stability, including the use of multiple storage endpoints. The application volume group feature supports a wide range of Oracle database layouts from small databases with a single volume up to multi-hundred TiB sized databases with up to 8 data volumes and with latency-optimized performance and only limited by the database VM's network capabilities.
Application volume group for Oracle is supported in all Azure NetApp Files enabled regions.
Learn more:
