跳转至主要内容
Enhanced performance with Azure VM families
March 10, 2026
With NetApp ONTAP® 9.18.1 data management software, Cloud Volumes ONTAP for Azure supports new virtual machine families that are optimized for end-to-end block (NVMe/TCP) and file workloads, all managed seamlessly through NetApp Console.
This upgrade delivers:
  • Improved performance and reduced latency across both block and file storage.
  • Significant gains for enterprise applications, enabling faster response times and smoother operations across diverse I/O profiles in cloud environments.
Explore Cloud Volumes ONTAP
