본문으로 건너뛰기
The power of seeing it all: Why unified observability changes the game
이 페이지 공유하기
Casey Wopat
Casey Wopat
Managing modern IT infrastructure often feels like trying to assemble a puzzle in the dark. You have pieces from different vendors—storage arrays here, virtual machines there, cloud instances floating around somewhere else—but seeing the full picture is nearly impossible.
This is where unified, AI-powered observability comes in. It’s not just about monitoring; it’s about clarity. NetApp Data Infrastructure Insights turns the lights on, giving you a single, cohesive view of your entire infrastructure. A recent IDC study highlights just how powerful unified observability with Data Infrastructure Insights can be; here are some of the lessons learned from our customers.
Simplify and Optimize: Enterprise Data Observabilty
Breaking down the silos
The biggest enemy of efficiency is the silo. Your storage team sees one thing, your virtualization team sees another, and the cloud team sees something else entirely. When performance dips, the finger-pointing begins.
Unified observability dismantles these walls. Data Infrastructure Insights connects the dots across your multi-vendor environment, mapping relationships from the VM all the way down to the LUN.
Efficiency for lean teams
You don't need a massive army of engineers to manage a complex global infrastructure effectively; you just need the right visibility. When your tools work harder, your team doesn't have to.
According to an IDC study on the business value of Data Infrastructure Insights, customers are finding immense value in this consolidated approach. One customer shared their experience:
“There were multiple reasons for choosing NetApp [Data Infrastructure Insights]. Our team is very small, yet we manage a globally distributed infrastructure that is largely outsourced, so efficiency was critical. With NetApp DII, we no longer need to contact different specialists for data like UUIDs or datastore names because the platform provides full visibility into servers, storage, and network paths in one place. It made infrastructure monitoring much easier.”
Another customer noted, “From our perspective, especially around storage, NetApp DII is super helpful because storage administrators now have full visibility and can access all the information themselves. They no longer need to go to compute, VMware, or power teams to get details like WWPNs. They can look everything up on their own.”
This is the power of unification. Instead of waiting for email replies or ticket updates to get a simple UUID, your team has the data at their fingertips. It empowers generalists to solve specialist problems and lets specialists focus on high-value projects rather than data fetching.
Troubleshooting at speed
Mean time to resolution is the metric that keeps storage teams up at night. When an application crawls, every minute counts. The traditional method involves "swivel-chair" troubleshooting—spinning between three different dashboards, trying to find the anomaly. With NetApp, you stop swiveling and start solving. Because Data Infrastructure Insights understands the topology of your infrastructure, it can instantly correlate events. It doesn't just show you a red light; it shows you why the light is red. In fact, Data Infrastructure Insights helps teams identify the root cause of issues 49% quicker.
One customer in the IDC study stated: “NetApp [Data Infrastructure Insights] has helped us pinpoint the root cause of issues faster because it provides us with a single dashboard. We can see everything in the infrastructure, including the topology from the server to the storage, and quickly identify where a failure has occurred. It is easy for us to recognize which server is failing and where it is connected to the SAN.”
Simplifying migrations
Complex migrations are often where monitoring tools fail. You are moving massive amounts of data and stressing the system in new ways. Another customer highlighted in the IDC study found Data Infrastructure Insights indispensable during a critical migration:
“My company selected NetApp DII because we needed a unified view of our multi-vendor environment. During a proof of concept for NetApp DII [Data Infrastructure Insights], we were migrating a large datacenter and encountered issues, and within 15 minutes, the tool helped identify a CPU-starved VMware server causing back pressure.”
Fifteen minutes. Compare that to the hours or even days it might take to manually trace that back pressure through logs and isolated metrics. Data Infrastructure Insights pinpointed a CPU issue on a server that was impacting storage performance—a classic cross-domain problem that siloed tools often miss.
Proactive management: predicting the future
Fixing things fast is good, but preventing them from breaking is better. Unified observability shifts your stance from reactive firefighting to proactive planning. Data Infrastructure Insights doesn't just look at what's happening now; it utilizes AI to analyze trends and tell you what will happen.
  • Capacity forecasting: Stop guessing when you'll run out of space. Data Infrastructure Insights looks at your usage trends and predicts exactly when you'll hit the wall, allowing you to budget and procure storage well in advance.
  • Risk Detection: Identify "noisy neighbors" or misconfigured assets before they cause an outage. Get alerts to anomalies that deviate from normal behavior, catching potential ransomware attacks or runaway processes early.
  • Cost Optimization: Are you paying for tier-one storage for tier-three data? Easily identify orphaned storage and cold data that can be moved to cheaper tiers, directly impacting your bottom line.
Proactivity was a huge boon for one customer: “NetApp [Data Infrastructure Insights] allows our system administrators to work proactively. It really helps them be ahead of problems versus chasing things all the time.”
The bottom line
You deserve tools that work as hard as you do. Managing a hybrid, multi-vendor environment is complex enough without fighting your own monitoring stack. NetApp Data Infrastructure Insights delivers the clarity you need. It simplifies the complex, connects the disconnected, and turns data into actionable intelligence. Whether you are a small team managing a global estate or a large enterprise navigating a migration, unified observability is the key to working smarter, not harder.
Explore the complete IDC study today.
IDC Business Value Solution Brief, Sponsored by NetApp, The Business Value of NetApp Data Infrastructure Insights, #US54271626-BVSB, March 2026
Casey Wopat
Casey Wopat
Casey Wopat is a senior product marketing manager at NetApp, responsible for the messaging and marketing of Data Infrastructure Insights (formerly Cloud Insights). Outside of the office, she serves as a board member of her local family resource center and enjoys exploring her home state of Colorado with her family and golden retriever.Casey Wopat의 모든 게시물 보기
다음 단계
