Salta al contenuto principale
Synextra
Create an affordable private-cloud service based on NetApp technology
Synextra Featured Image
Customer Logo - Synextra
Synextra
Leveraging NetApp Portfolio for Highly Successful Platform On Demand
UK cloud provider Synextra recently took the market by storm—and doubled its monthly revenues—with Platform On Demand (POD), combining dedicated servers with a shared storage array to deliver true cloud benefits at an affordable cost. Underlying the POD offering are NetApp storage and data management, including ONTAP Select and StorageGRID.
Being software-defined, ONTAP Select gives us a lot of ease, flexibility, speed, and scalability. You can buy any quantity you require. If you buy a 50TB license, you can add 10TB or 20TB more as needed, then run it off essentially any storage. It's very reliable and efficient; we can simply mirror our primary system, taking full advantage of dedupe and compression.
Chris Piggott, Co-founder and Technical Director, Synextra
“Our clients want optimum performance and instant control without the onerous upfront cost of buying their own infrastructure,” said Chris Piggott, co-founder and technical director of Synextra. “We identified a gap in the market and created POD, using NetApp technology, to provide private-cloud services for midsize and enterprise customers. POD is the best way we know to support their business growth.”
Synextra's primary storage is the NetApp AFF system. Its back-end storage platform is NetApp E-Series Hybrid Flash Storage. Recently, Synextra also deployed NetApp ONTAP Select and NetApp StorageGRID, at times surprising even NetApp with its use-case innovations.
To run its disaster recovery (DR) data center, Synextra chose ONTAP Select software-defined data storage. Part of the NetApp Data Fabric, ONTAP Select can quickly communicate with and transfer data among other storage endpoints across the fabric. As Synextra's secondary storage solution, ONTAP Select leverages the company's back-end E-Series platform. Synextra uses it in conjunction with NetApp SnapMirror, which provides unified replication for the Data Fabric and leverages ONTAP storage efficiencies by sending only changed blocks over the network.
Results
2x
revenue growth over 3 months
NetApp Solutions
Learn More
Make your move
