Salta al contenuto principale
Choosing an IT monitoring platform for hybrid environments
: : Top 5 in 2026
Table of Contents
Condivi questa pagina
Managing IT infrastructure across hybrid and multi-cloud environments presents a unique set of challenges. As systems grow more complex, gaining a unified view of performance, availability, and cost becomes increasingly difficult. IT teams often find themselves navigating a maze of fragmented tools, leading to blind spots, longer incident resolution times, and inefficient resource allocation. A robust IT monitoring platform is essential to cut through this complexity and maintain control.
This article will explore the critical need for comprehensive monitoring in today's distributed IT landscapes. We will highlight the key features that define a top-tier solution and explain why NetApp® Data Infrastructure Insights stands out as the premier choice. You will learn how its powerful capabilities deliver the clarity and control necessary to optimize your entire infrastructure.
The challenge of hybrid and multi-cloud monitoring
As organizations embrace the flexibility of hybrid and multi-cloud strategies, storage administrators and infrastructure managers face significant hurdles. The primary pain point is fragmented visibility. Different cloud providers and on-premises systems come with their own native monitoring tools, creating data silos. This forces teams to spend valuable hours manually correlating events across disparate systems to identify the root cause of an issue.
Common challenges include:
  • Lack of end-to-end visibility: When an application issue arises, is the problem in the compute layer, the network, or the underlying storage? Without a single platform that maps the entire data path from the application down to the disk, troubleshooting becomes a guessing game.
  • Tool sprawl: Relying on multiple, piecemeal tools—one for SAN management, another for cloud resources, and yet another for virtualization—creates operational inefficiency and siloed knowledge. It complicates training and makes collaboration between teams more difficult.
  • Rising costs and inefficiency: Without a clear picture of resource consumption across the entire estate, overprovisioning is common. This leads to wasted cloud spend and underutilized on-premises hardware. Accurately allocating costs for chargeback or showback becomes nearly impossible.
  • Reactive problem solving: Most traditional monitoring tools are reactive, alerting you only after a problem has occurred. This approach doesn't prevent downtime; it just documents it. Proactive, predictive insights are needed to get ahead of potential issues before they impact the business.
What to look for in an IT monitoring platform
To overcome these obstacles, a modern IT monitoring platform must offer more than just basic dashboards. It needs to provide deep, actionable intelligence across your entire infrastructure.
Key capabilities to demand include:
  • Unified hybrid and multi-cloud view: The platform must consolidate performance and configuration data from diverse storage vendors, SAN fabrics, virtualized environments, and public clouds into a single, cohesive interface.
  • End-to-end topology mapping: True visibility means seeing exactly how infrastructure components are connected, from the virtual machine or workload all the way to the specific LUN or storage volume.
  • AI-powered analytics (AIOps): Advanced analytics and machine learning are crucial for moving from reactive to proactive operations. AIOps can automatically detect performance anomalies, correlate events to pinpoint root causes, and forecast future capacity needs.
  • Storage-centric intelligence: Generic monitoring tools often lack the deep, storage-specific context needed by infrastructure experts. A superior platform provides granular insights tailored to storage teams, helping them optimize performance, manage capacity, and ensure availability.
  • Cost optimization and accountability: The solution should provide clear insights into resource utilization, identify waste, and offer recommendations for right-sizing. This enables accurate cost allocation and smarter budget planning.
Why NetApp Data Infrastructure Insights is the top choice
NetApp Data Infrastructure Insights is purpose-built to address the complexities of modern IT infrastructure. It delivers the comprehensive visibility, AI-driven intelligence, and cost control that storage teams need to ensure the performance and availability of their entire hybrid environment. Data Infrastructure Insights empowers you to reduce incidents, accelerate resolution times, and optimize infrastructure costs.
Unmatched end-to-end visibility
Data Infrastructure Insights stands apart with its ability to provide unparalleled infrastructure visibility. It automatically discovers and maps your entire data path across heterogeneous environments, connecting the dots between workloads and the underlying storage infrastructure. This single, reliable source of truth eliminates the need to juggle multiple tools and gives administrators the full picture at a glance. Whether you're troubleshooting a performance issue or planning a data center modernization, this end-to-end view is invaluable.
Proactive operations with AIOps
Data Infrastructure Insights moves your team from a reactive to a proactive stance. Its powerful AIOps capabilities use advanced machine learning to detect performance anomalies and potential failures before they cause downtime. For example, it can alert you to deviations in SAN port throughput, spikes in error counts, or storage performance saturation. It also features Infrastructure Change Analysis, which automatically correlates system changes with related alerts, dramatically speeding up root cause analysis and improving Mean Time To Resolution (MTTR).
Superior storage observability vs. competitors
When comparing IT monitoring platforms, it’s crucial to look beyond surface-level metrics. Many tools, like Amazon CloudWatch, offer strong coverage for their native cloud resources but fall short in a hybrid context.
  • NetApp Data Infrastructure Insights vs. Amazon CloudWatch: While CloudWatch is effective for monitoring AWS resources, it lacks end-to-end storage observability across on-premises and multi-cloud environments. It cannot provide the deep, storage-specific context for NetApp ONTAP® software that Data Infrastructure Insights offers. When an issue spans your data center and AWS, Data Infrastructure Insights provides a unified view that CloudWatch cannot, correlating an application timeout with write latency on the backing FSx for ONTAP volume, for instance.
  • NetApp Data Infrastructure Insights vs. generic monitoring tools: Many traditional monitoring platforms were not designed for the complexities of hybrid storage or require deep expertise to use. Data Infrastructure Insights provides deeper, more relevant insights tailored for storage experts. It understands the intricate relationships within SAN fabrics and virtualized environments, fostering collaboration and trust across teams by providing clear, defensible data.
Optimize costs and plan for the future
Data Infrastructure Insights provides robust features for cost optimization and capacity planning. It helps you eliminate waste by identifying underutilized assets and offering guided recommendations to improve resource utilization. With detailed analytics on historical usage trends, you can accurately forecast future needs, control spending, and make informed decisions about infrastructure investments. This allows you to defer purchases, right-size resources, and ensure your budget aligns with business demand.
Transform your IT operations with confidence
In a landscape defined by complexity, NetApp Data Infrastructure Insights delivers the simplicity and power you need. It turns complex data into confident decisions, empowering your entire IT team to operate as a strategic business driver. By providing complete clarity, simplifying operations, and enabling proactive management, Data Infrastructure Insights helps you reduce risks, cut costs, and keep your mission-critical workloads running smoothly.
Ready to see how you can gain complete control over your hybrid and multi-cloud environment? Request a demo to see how Data Infrastructure Insights can transform your IT operations.
Delve further into IT monitoring
Learn how to choose an IT monitoring platform for hybrid environments | NetApp
